Salta al contenuto principale
PlayStation 3 Wi-Fi Antenna Replacement
Cosa ti serve
  1. PlayStation 3 Wi-Fi Antenna Replacement, Smart Plate: passo 1, immagine 1 di 2 PlayStation 3 Wi-Fi Antenna Replacement, Smart Plate: passo 1, immagine 2 di 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Wi-Fi Antenna Replacement: passo 2, immagine 1 di 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Wi-Fi Antenna Replacement: passo 3, immagine 1 di 3 PlayStation 3 Wi-Fi Antenna Replacement: passo 3, immagine 2 di 3 PlayStation 3 Wi-Fi Antenna Replacement: passo 3, immagine 3 di 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Wi-Fi Antenna Replacement: passo 4, immagine 1 di 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Wi-Fi Antenna Replacement, Top Cover: passo 5, immagine 1 di 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Wi-Fi Antenna Replacement: passo 6, immagine 1 di 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Wi-Fi Antenna Replacement, Memory Card Reader: passo 7, immagine 1 di 1
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  8. PlayStation 3 Wi-Fi Antenna Replacement: passo 8, immagine 1 di 2 PlayStation 3 Wi-Fi Antenna Replacement: passo 8, immagine 2 di 2
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
  9. PlayStation 3 Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 9, immagine 1 di 1
    • Use the flat end of a spudger to pry the Wi-Fi antenna connector off its socket on the Wi-Fi/Bluetooth board.
  10. PlayStation 3 Wi-Fi Antenna Replacement: passo 10, immagine 1 di 1
    • De-route the Wi-Fi antenna cable from the gap between the power supply and the Blu-ray drive.
  11. PlayStation 3 Wi-Fi Antenna Replacement: passo 11, immagine 1 di 1
    • Remove the 9 mm Phillips screw securing the Wi-Fi antenna to the chassis.
  12. PlayStation 3 Wi-Fi Antenna Replacement: passo 12, immagine 1 di 1
    • Remove the Wi-Fi antenna, minding its cable that may get caught.
Conclusione
Altre 17 persone hanno completato questa guida.
3 Commenti
I used this guide to remove the stock antenna, learn my way through the PS3, and add a new external antenna. I removed the old one and bought an 8 inch 6 dbi antenna and a 12 inch R-SMA female pigtail adapter. Then drilled a hole with a 1/4" drill bit, attached the adapter, inserted the wire to the motherboard where the old one was connected, screwed on the antenna, and put everything back together. 5 times the internet speed!!! I did have to remove the power supply and disk drive however to get to the wire but still I never would have been able to complete this without the guide! Thanks to whoever did that! :D
The Pianoman - Replica
Pretty good guide! I just replaced my wifi antenna on my old ps3. I have to say that it was pretty easy since I never opened an ps3 before.
Michal S. - Replica
Yeah didn't quiet happen that way
Aaron Paul Bugg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 94
Tutti i Tempi: 40,571
