Salta al contenuto principale
PlayStation 3 Slim Lower Case Replacement
Cosa ti serve
  1. PlayStation 3 Slim Lower Case Replacement, Top Cover: passo 1, immagine 1 di 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Lower Case Replacement: passo 2, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement: passo 2, immagine 2 di 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Lower Case Replacement: passo 3, immagine 1 di 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Lower Case Replacement: passo 4, immagine 1 di 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Lower Case Replacement: passo 5, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement: passo 5, immagine 2 di 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Lower Case Replacement, Power Supply: passo 6, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement, Power Supply: passo 6, immagine 2 di 2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim Lower Case Replacement: passo 7, immagine 1 di 1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim Lower Case Replacement: passo 8, immagine 1 di 1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim Lower Case Replacement: passo 9, immagine 1 di 1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim Lower Case Replacement: passo 10, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement: passo 10, immagine 2 di 2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim Lower Case Replacement, Blu-ray Disc Drive: passo 11, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement, Blu-ray Disc Drive: passo 11, immagine 2 di 2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  12. PlayStation 3 Slim Lower Case Replacement: passo 12, immagine 1 di 1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  13. PlayStation 3 Slim Lower Case Replacement: passo 13, immagine 1 di 1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  14. PlayStation 3 Slim Lower Case Replacement: passo 14, immagine 1 di 1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  15. PlayStation 3 Slim Lower Case Replacement: passo 15, immagine 1 di 1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  16. PlayStation 3 Slim Lower Case Replacement: passo 16, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement: passo 16, immagine 2 di 2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
  17. PlayStation 3 Slim Lower Case Replacement, Motherboard Assembly: passo 17, immagine 1 di 1
    • Pull the AC-In cables upward to remove the AC inlet from the lower case.
  18. PlayStation 3 Slim Lower Case Replacement: passo 18, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement: passo 18, immagine 2 di 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
  19. PlayStation 3 Slim Lower Case Replacement: passo 19, immagine 1 di 1
    • Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Remove the control board.
  20. PlayStation 3 Slim Lower Case Replacement: passo 20, immagine 1 di 1
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  21. PlayStation 3 Slim Lower Case Replacement: passo 21, immagine 1 di 1
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  22. PlayStation 3 Slim Lower Case Replacement: passo 22, immagine 1 di 1
    • Using its attached metal handle, pull the hard drive out of its bay.
  23. PlayStation 3 Slim Lower Case Replacement: passo 23, immagine 1 di 1
    • Remove the following five screws securing the motherboard assembly to the lower case:
    • Two silver 6 mm Phillips
    • Three black 8 mm Phillips
  24. PlayStation 3 Slim Lower Case Replacement: passo 24, immagine 1 di 1
    • Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Be careful not to bend the metal antenna bodies as you lift the motherboard assembly.
  25. PlayStation 3 Slim Lower Case Replacement, Lower Case: passo 25, immagine 1 di 1
    • Remove the two 6.2 mm Phillips screws securing the antennas to the lower case.
  26. PlayStation 3 Slim Lower Case Replacement: passo 26, immagine 1 di 2 PlayStation 3 Slim Lower Case Replacement: passo 26, immagine 2 di 2
    • Lift the antennas out of their plastic alignment posts and remove them from the lower case.
    • The lower case is all that remains.
Conclusione
Altre 13 persone hanno completato questa guida.
Un commento
On my model 3003, after reaching the end I flipped my bottom case over for dust removal etc and a silver clip fell off. I think it was located on the right (from front) side of the unit. There is another larger one attached slightly further forward. Does anyone know how the smaller one fits back in? It appears to have 2 semicircles cut out of one part which look like screw guides but I can't see anywhere they might fit and nothing I've seen here or elswhere is helping with this. Any ideas please?
Pete B - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 91
Tutti i Tempi: 19,971
