Salta al contenuto principale
PlayStation 3 Slim Laser lens Replacement
Cosa ti serve
Panoramica Video
  1. PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: passo 1, immagine 1 di 2 PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: passo 1, immagine 2 di 2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  2. PlayStation 3 Slim Laser lens Replacement: passo 2, immagine 1 di 1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  3. PlayStation 3 Slim Laser lens Replacement: passo 3, immagine 1 di 1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  4. PlayStation 3 Slim Laser lens Replacement: passo 4, immagine 1 di 1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  5. PlayStation 3 Slim Laser lens Replacement: passo 5, immagine 1 di 1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  6. PlayStation 3 Slim Laser lens Replacement: passo 6, immagine 1 di 2 PlayStation 3 Slim Laser lens Replacement: passo 6, immagine 2 di 2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
Conclusione
Altre 20 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
5 Commenti
Donde puedo comprar refacciones y partes para PS3 Slim?
David - Replica
yo vendo amigo = ivaramso@gmail.com para ventas
Ivan Ramirez -
How can this be easy, but the Blu-Ray drive be considered Moderate? You need to complete the Blu-Ray drive removal prior to replacing the laser lens, which means this is at best a Moderate task.
Ben Kevan - Replica
This is not lens replacement, this is drive replacement. Is there a separate guide for lens replacement?
cmchallam - Replica
Shows how to do the laser assembly in the video but not how to reinstall it in the drive. Lazy guide. Just buy a whole new drive if you are following this guide.
Beninja - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 117
Tutti i Tempi: 32,599
