Salta al contenuto principale
PlayStation 3 Slim Laser Unit (Laser and Mechanism) Replacement
Cosa ti serve
Panoramica Video
  1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): passo 1, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): passo 1, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): passo 1, immagine 3 di 3
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 2, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 2, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 2, immagine 3 di 3
    • To remove the power supply, first disconnect the two cables, then the 2 Phillips screws. Then lift it upwards.
  3. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 3, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 3, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 3, immagine 3 di 3
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
    • Depending on the model of your PS3 Slim, the number of cables to be removed may vary between 2 and 4. If your model has more than one ribbon cable, remove the drive very carefully, as a fourth ribbon cable may be hidden underneath.
  4. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 4, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 4, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 4, immagine 3 di 3
    • Disassemble the upper metal shield by first unscrewing the 3 Phillips screws.
    • On the 2-cables model, you'll need to unscrew an additional 2 small Phillips screws, located on the underside of the drive. While you're at it, unscrew the 2 other Phillips screws at the bottom of the shield. (Their presence does not prevent removal of the upper metal shield, but removing them will be useful later).
  5. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 5, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 5, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 5, immagine 3 di 3
    • For the 2-cables model, remove the two very small phillips screws in each lower corner referenced by the red circles.
    • For the 4-cables model, remove the small Phillips screw in the bottom left corner referenced by the red circle.
  6. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 6, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 6, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 6, immagine 3 di 3
    • Carefully remove the plastic shell, paying attention to the cable that runs through it for the 4-cables model.
  7. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 7, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 7, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 7, immagine 3 di 3
    • Remove the 4 Phillips screws at each corner of the laser mechanism.
    • Then remove the mechanism.
  8. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 8, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 8, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 8, immagine 3 di 3
    • If necessary, transfer parts and screws from the old mechanism to the new one.
  9. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 9, immagine 1 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 9, immagine 2 di 3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: passo 9, immagine 3 di 3
    • You can test the console before full assembling.
    • To do this, reassemble the blu-ray drive, reconnect its cables, and reconnect the power supply.
Conclusione
Altre 16 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.278 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
Un commento
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
Edmond Charrette - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 260
Tutti i Tempi: 28,762
