Salta al contenuto principale
Introduzione
Use this guide to replace your PlayStation 3's heat sink. Before reattaching the heat sink, it is essential to apply a new layer of thermal paste.
  1. Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3. The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. Remove the following seven screws:
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
  7. Disconnect the Blu-ray power cable from the motherboard.
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself. Pull the ribbon cable out of its socket.
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. Pull the control board ribbon cable straight up and out of its socket on the motherboard.
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. Remove the two 12 mm Phillips screws securing the control board to the lower case. Remove the control board and its attached cable from the PS3.
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. Remove the following eight screws securing the motherboard assembly to the lower case:
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. Remove the control board bracket.
    • Remove the control board bracket.
  14. Use the flat end of a spudger to pry the hard drive bay cover away from the lower case. Remove the hard drive bay cover.
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. Lift the motherboard assembly out of the lower case.
    • Lift the motherboard assembly out of the lower case.
  16. Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
    • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
  17. Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector. While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
    • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  18. Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
    • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
  19. While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover. While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
    • While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
  20. Remove the rear cover from the logic board assembly.
    • Remove the rear cover from the logic board assembly.
  21. De-route the fan cables from the plastic finger molded into the heat sink. Disconnect the fan from the motherboard.
    • De-route the fan cables from the plastic finger molded into the heat sink.
    • Disconnect the fan from the motherboard.
  22. Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  23. Lift the memory card reader out of the PS3 enough to access its ribbon cable. Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Lift the memory card reader out of the PS3 enough to access its ribbon cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Pull the ribbon cable out of its socket and remove the memory card reader.
  24. Disconnect the DC-In cables from the front of the heat sink.
    • Disconnect the DC-In cables from the front of the heat sink.
    • Pull the connector toward the front of the PS3.
  25. Remove the five 9 mm Phillips screws securing the power supply to the chassis.
    • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
  26. Lift the power supply by its front edge to clear the two posts attached to the motherboard.
    • Lift the power supply by its front edge to clear the two posts attached to the motherboard.
    • Remove the power supply.
  27. Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
    • Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
    • Remove the two brackets held under the screws you just removed.
  28. Lift the motherboard assembly off the heat sink.
    • Lift the motherboard assembly off the heat sink.
    • The heat sink may still be held in place by the thermal paste. If this is the case, gently pry the heat sink away from the motherboard housing. Make sure to not bend the copper piping on the heat sink.
    • Be sure to apply a new layer of thermal paste when reattaching the heat sink.
    • Never applied thermal paste before? Our thermal paste guide makes it easy.
    • If you're following the YLOD repair guide, stay tuned for where to apply the replacement thermal paste.
  29. Remove the three 5.7 mm #0 Phillips screws securing the fan to the heat sink.
    • Remove the three 5.7 mm #0 Phillips screws securing the fan to the heat sink.
  30. Remove the fan from the heat sink, minding its cables that may get caught.
    • Remove the fan from the heat sink, minding its cables that may get caught.
Conclusione
Altre 49 persone hanno completato questa guida.
7 Commenti
Thank you for the help
G Y - Replica
i make thermal compounds. just wondering do i need to use a grease that has silver or is an aluminum based grease good to use
bjornsenjosh99 - Replica
Thanks a lot! It is very useful!
Wing Leung Lin - Replica
I know this is old but what thermal paste should I use today
Shane Rennie - Replica
I recommend artic silver or MX-4 since I heard that it's supposed to last up to 8 years. As long as you don't have to disassemble the console again
Antrone Harris Jr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 124
Ultimi 30 Giorni: 481
Tutti i Tempi: 104,795
