Salta al contenuto principale
PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement
Cosa ti serve
  1. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement, Lower Smart Plate: passo 1, immagine 1 di 1
    • Turn off your PlayStation 2 and remove the disc and Memory Card.
    • Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
  2. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: passo 2, immagine 1 di 1
    • Locate the six covers.
    • Two are located underneath the feet.
    • One cover is located underneath the Void sticker.
  3. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: passo 3, immagine 1 di 1
    • Remove the Void sticker with a Spudger and some cleaning alcohol
    • Removing the Void sticker will void the warranty of your device!
    • Some versions of that console maybe don’t have the sticker or it’s relocated.
  4. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: passo 4, immagine 1 di 2 PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: passo 4, immagine 2 di 2
    • Remove the covers by using either a Spudger, Opening Picks or your fingernail.
  5. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: passo 5, immagine 1 di 1
    • Remove the six Phillips #1 screws with a screwdriver.
    • The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
  6. PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: passo 6, immagine 1 di 2 PlayStation 2 Slimline SCPH-900xx Lower Smart Plate Replacement: passo 6, immagine 2 di 2
    • Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
    • Separate the two halves.
Conclusione
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
MrJulian ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
MrJulian
Membro da: 10/22/20
2.109 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 57
Tutti i Tempi: 2,321
