Salta al contenuto principale
PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement
Cosa ti serve
  1. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement, Lower Smart Plate: passo 1, immagine 1 di 1
    • Turn off your PlayStation 2 and remove the disc and Memory Card.
    • Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
  2. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 2, immagine 1 di 1
    • Locate the six covers.
    • Two are located underneath the feet.
    • One cover is located underneath the Void sticker.
  3. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 3, immagine 1 di 1
    • Remove the Void sticker with a Spudger and some cleaning alcohol
    • Removing the Void sticker will void the warranty of your device!
    • Some versions of that console maybe don’t have the sticker or it’s relocated.
  4. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 4, immagine 1 di 2 PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 4, immagine 2 di 2
    • Remove the covers by using either a Spudger, Opening Picks or your fingernail.
  5. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 5, immagine 1 di 1
    • Remove the six Phillips #1 screws with a screwdriver.
    • The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
  6. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 6, immagine 1 di 2 PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 6, immagine 2 di 2
    • Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
    • Separate the two halves.
  7. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement, Clock Battery: passo 7, immagine 1 di 1
    • The clock battery is located under the drive.
    • Do not touch the Laser (red circle)! Otherwise it can’t read the disc anymore!
    • Make sure that the sensor array for the on/off switch sits correctly when reassembling the device.
    • This picture shows the European model (SCPH-90004). Some models with other region codes may not have a clock battery.
  8. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: passo 8, immagine 1 di 1
    • Pull away the metal mounting on the right to remove the old button cell.
    • Replace the old button cell/clock battery with a new button cell type CR 2032 with 3V of voltage.
Conclusione
Altre 7 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
MrJulian
Membro da: 10/22/20
2.109 Reputazione
7 Guide realizzate
5 Commenti
Simple and easy to follow. I really do miss how straightforward it used to be to take apart game consoles.
Melsypoo - Replica
Everything is okay but how I can extract drive?
Memozit - Replica
Hey Memozit,
To remove the optical drive of the PS2 follow this guide: PlayStation 2 Slimline SCPH-900xx Laufwerk ersetzen
Greetings
MrJulian
MrJulian -
I opened up my slim silver ps2 scph-90001, can't find the cmos battery anywhere. It's not under the fan, it's not under the motherboard. This is the American silver version. I have the replacement battery I just don't know where to put it.
Cory - Replica
Hey Cory,
The PS2 shown in the guide is a European model (SCPH-90004) which has a CMOS battery. The guide mentions that other region models may not have a clock battery which could be the case on 01 models (Northern America).
Greetings
MrJulian
MrJulian -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 90
Ultimi 30 Giorni: 325
Tutti i Tempi: 12,960
