Salta al contenuto principale
PlayStation 2 Slimline Optical Drive Replacement
Cosa ti serve
  1. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 1, immagine 2 di 3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: passo 1, immagine 3 di 3
    • Remove the rubber feet on two of the screw covers on the bottom of the console.
    • Remove the screw covers and the screws themselves.
    • Caution: One of the screws is underneath the "Do not void" seal
  2. PlayStation 2 Slimline Optical Drive Replacement: passo 2, immagine 1 di 2 PlayStation 2 Slimline Optical Drive Replacement: passo 2, immagine 2 di 2
    • If all screws are removed.
    • Use a metal spunger to open the chassis
  3. PlayStation 2 Slimline Optical Drive Replacement: passo 3, immagine 1 di 3 PlayStation 2 Slimline Optical Drive Replacement: passo 3, immagine 2 di 3 PlayStation 2 Slimline Optical Drive Replacement: passo 3, immagine 3 di 3
    • Slip the three cables out of the sockets.
    • Use a PH01 screwdriver to remove the four screws securing the optical drive
    • Lift up the optical drive and remove the duct tape under the flex cable.
    • Now the optical drive is free and ready for replacement
Conclusione
Altre 16 persone hanno completato questa guida.
tlroesner
Membro da: 05/13/12
1.864 Reputazione
4 Guide realizzate
3 Commenti
How is it that this guide says difficult and the other PS2 drive replacement on here says easy?
Mark - Replica
it really depends on your level of skill/experience.
Damien Simons -
How many different versions of drive is there for the slim model? When you go to replace it, do you just compare the model number on the laser?
Trevor V - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 90
Tutti i Tempi: 22,073
