Salta al contenuto principale
PlayStation 2 Slimline Motherboard Replacement
Cosa ti serve
  1. PlayStation 2 Slimline Motherboard Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Motherboard Replacement: passo 2, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 2, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 2, immagine 3 di 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Motherboard Replacement: passo 3, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 3, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Motherboard Replacement: passo 4, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 4, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 4, immagine 3 di 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Motherboard Replacement, Fan: passo 5, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement, Fan: passo 5, immagine 2 di 2
    • Locate the fan at the front, left section of the unit.
  6. PlayStation 2 Slimline Motherboard Replacement: passo 6, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 6, immagine 2 di 2
    • Peel off the sticker holding the power cords to the unit.
  7. PlayStation 2 Slimline Motherboard Replacement: passo 7, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 7, immagine 2 di 2
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  8. PlayStation 2 Slimline Motherboard Replacement: passo 8, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 8, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
    • Gently lift and remove the fan from its compartment.
  9. PlayStation 2 Slimline Motherboard Replacement, Clock Battery: passo 9, immagine 1 di 1
    • Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
  10. PlayStation 2 Slimline Motherboard Replacement: passo 10, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 10, immagine 2 di 2
  11. PlayStation 2 Slimline Motherboard Replacement: passo 11, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 11, immagine 2 di 2
    • Gently lift and remove the battery from its compartment using a spudger.
  12. PlayStation 2 Slimline Motherboard Replacement, IR Sensor: passo 12, immagine 1 di 1
    • Locate the IR sensor at the front, right corner of the unit.
  13. PlayStation 2 Slimline Motherboard Replacement: passo 13, immagine 1 di 1
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  14. PlayStation 2 Slimline Motherboard Replacement: passo 14, immagine 1 di 1
    • Gently lift and remove the IR Sensor from its designated slot.
  15. PlayStation 2 Slimline Motherboard Replacement, Optical Drive: passo 15, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement, Optical Drive: passo 15, immagine 2 di 2
    • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
  16. PlayStation 2 Slimline Motherboard Replacement: passo 16, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 16, immagine 2 di 2
    • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
  17. PlayStation 2 Slimline Motherboard Replacement: passo 17, immagine 1 di 1
    • Locate the three ribbon cables connecting the optical drive to the motherboard.
  18. PlayStation 2 Slimline Motherboard Replacement: passo 18, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 18, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 18, immagine 3 di 3
    • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
    • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
    • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  19. PlayStation 2 Slimline Motherboard Replacement: passo 19, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 19, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 19, immagine 3 di 3
    • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
    Be really careful when dealing with the orange ribbon cable attached to the optical lens, as it is glued on the metal surface underneath it. From normal usage months or years, and the optical lens natural movement, this ribbon might lose some glue and start lifting upwards, sometimes even touching the CD surface. This could start scratching your games to an unplayable extent. Reapply glue if needed.
    Americo Santos Oliveira - Replica
    You don't necessarily need to remove the ribbon cable from the shield. After you detached the cable from the motherboard, flip the optical drive and detach the other end of the cable.
    Vincenzo Quinci - Replica
  20. PlayStation 2 Slimline Motherboard Replacement, Motherboard: passo 20, immagine 1 di 1
    • Remove the 2.4 mm screw located in between the controller ports using a #1 Phillips screwdriver.
  21. PlayStation 2 Slimline Motherboard Replacement: passo 21, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 21, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 21, immagine 3 di 3
    • Gently lift and remove the motherboard and chassis from the outer shell.
  22. PlayStation 2 Slimline Motherboard Replacement: passo 22, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 22, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 22, immagine 3 di 3
    • There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard.
    • Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
  23. PlayStation 2 Slimline Motherboard Replacement: passo 23, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 23, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 23, immagine 3 di 3
    • Gently separate the two metal plates from the motherboard.
Conclusione
Altre 33 persone hanno completato questa guida.
Thomas Sullivan
Membro da: 10/23/13
3.927 Reputazione
6 Guide realizzate
2 Commenti
نرجو اضافة اللغة العربية
Muammar lmgaroush - Replica
Mi placa no tiene corriente, seguro tiene un corto quien me ayuda a solucionar, es la 77001, ya tiene botón y flex nuevo y no me da luz Led
gasper6913 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 208
Tutti i Tempi: 24,982
