Salta al contenuto principale
PlayStation 2 Slimline Motherboard Replacement
Cosa ti serve
  1. PlayStation 2 Slimline Motherboard Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Motherboard Replacement: passo 2, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 2, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 2, immagine 3 di 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Motherboard Replacement: passo 3, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 3, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Motherboard Replacement: passo 4, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 4, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 4, immagine 3 di 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Motherboard Replacement, Fan: passo 5, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement, Fan: passo 5, immagine 2 di 2
    • Locate the fan at the front, left section of the unit.
  6. PlayStation 2 Slimline Motherboard Replacement: passo 6, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 6, immagine 2 di 2
    • Peel off the sticker holding the power cords to the unit.
  7. PlayStation 2 Slimline Motherboard Replacement: passo 7, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  8. PlayStation 2 Slimline Motherboard Replacement: passo 8, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 8, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
    • Gently lift and remove the fan from its compartment.
  9. PlayStation 2 Slimline Motherboard Replacement, Clock Battery: passo 9, immagine 1 di 1
    • Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
  10. PlayStation 2 Slimline Motherboard Replacement: passo 10, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 10, immagine 2 di 2
  11. PlayStation 2 Slimline Motherboard Replacement: passo 11, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 11, immagine 2 di 2
    • Gently lift and remove the battery from its compartment using a spudger.
  12. PlayStation 2 Slimline Motherboard Replacement, IR Sensor: passo 12, immagine 1 di 1
    • Locate the IR sensor at the front, right corner of the unit.
  13. PlayStation 2 Slimline Motherboard Replacement: passo 13, immagine 1 di 1
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  14. PlayStation 2 Slimline Motherboard Replacement: passo 14, immagine 1 di 1
    • Gently lift and remove the IR Sensor from its designated slot.
  15. PlayStation 2 Slimline Motherboard Replacement, Optical Drive: passo 15, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement, Optical Drive: passo 15, immagine 2 di 2
    • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
  16. PlayStation 2 Slimline Motherboard Replacement: passo 16, immagine 1 di 2 PlayStation 2 Slimline Motherboard Replacement: passo 16, immagine 2 di 2
    • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
  17. PlayStation 2 Slimline Motherboard Replacement: passo 17, immagine 1 di 1
    • Locate the three ribbon cables connecting the optical drive to the motherboard.
  18. PlayStation 2 Slimline Motherboard Replacement: passo 18, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 18, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 18, immagine 3 di 3
    • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
    • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
    • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  19. PlayStation 2 Slimline Motherboard Replacement: passo 19, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 19, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 19, immagine 3 di 3
    • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
  20. PlayStation 2 Slimline Motherboard Replacement, Motherboard: passo 20, immagine 1 di 1
    • Remove the 2.4 mm screw located in between the controller ports using a #1 Phillips screwdriver.
  21. PlayStation 2 Slimline Motherboard Replacement: passo 21, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 21, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 21, immagine 3 di 3
    • Gently lift and remove the motherboard and chassis from the outer shell.
  22. PlayStation 2 Slimline Motherboard Replacement: passo 22, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 22, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 22, immagine 3 di 3
    • There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard.
    • Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
  23. PlayStation 2 Slimline Motherboard Replacement: passo 23, immagine 1 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 23, immagine 2 di 3 PlayStation 2 Slimline Motherboard Replacement: passo 23, immagine 3 di 3
    • Gently separate the two metal plates from the motherboard.
Conclusione
Altre 38 persone hanno completato questa guida.
Thomas Sullivan
Membro da: 10/23/13
4.735 Reputazione
6 Guide realizzate
2Commenti sulla guida
نرجو اضافة اللغة العربية
Muammar lmgaroush - Replica Condividi
Mi placa no tiene corriente, seguro tiene un corto quien me ayuda a solucionar, es la 77001, ya tiene botón y flex nuevo y no me da luz Led
gasper6913 - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 21
Ultimi 7 Giorni: 114
Ultimi 30 Giorni: 426
Tutti i Tempi: 32,903
