Salta al contenuto principale
PlayStation 2 Slimline CMOS Battery Replacement
Cosa ti serve
  1. PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, immagine 1 di 2 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: passo 1, immagine 2 di 2
    • Remove all five screws on the downside of the PS2 Slimline
    • Underneath the "Do not remove" sticker, there will be one last screw
    Chiedi a FixBot
    Aggiungi Commento
  2. PlayStation 2 Slimline CMOS Battery Replacement, Remove the plate: passo 2, immagine 1 di 2 PlayStation 2 Slimline CMOS Battery Replacement, Remove the plate: passo 2, immagine 2 di 2
    • Using a metal spudger, carefully pry open the chassis
    • Although a metal spudger is used in the tutorial, it is recommended to use plastic spudgers with most electronics as metal on metal can short circuts
    Chiedi a FixBot
    Aggiungi Commento
  3. PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: passo 3, immagine 1 di 3 PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: passo 3, immagine 2 di 3 PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: passo 3, immagine 3 di 3
    • Locate the battery on the motherboard. The battery will be a CR2032 Button Cell Battery
    • Carefully use a metal spudger to pull the battery out of the metal housing
    • Once the battery is fully removed, remove the connector upwards from the motherboard
    • The connector does not have any clips and can be easily removed and pushed back in with reassembly/disassembly
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
tlroesner
Membro da: 05/13/12
1.891 Reputazione
4 guide realizzate
3Commenti sulla guida
why would i need to do this?
Dimitrios Frantzis - Rispondi Condividi
To prior poster, you will not be able to effectively play certain types of games once the server is shut off by Sony.
Joe W. - Rispondi Condividi
What do I replace the battery with? Can I re-apply the rubber casing of the original battery onto a new 2032 or what?
Jarad Webb - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 81
Ultimi 30 giorni: 320
Tutti i Tempi: 15,374
