Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
In the need that you need to replace the entire disc drive, here's what you need to do. You may need to do a little eBay perusing first, but when you find that replacement, these steps will show you how to remove your old one.
Panoramica Video
  1. Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards. Use the flat edge of a metal spudger to pry the eight flat screw covers out. Remove the following eight screws securing the top cover to the bottom case:
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    Before proceeding to step 2, Take a look at your PS2, some PS2's have 10 screws (and screw covers) instead of 8 (i found them underneath the optical drive), these instructions have mislead me and i ended up breaking my top cover for my PS2.
    Tristan - Replica
  2. Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. Flip the PlayStation 2 back to its original upside position. Lift the top cover off the bottom case.
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the bottom case.
  5. Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case. Lift and remove the optical disc drive straight up out of the bottom case.
    • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
    • Lift and remove the optical disc drive straight up out of the bottom case.
  6. Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case. Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
    • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
  7. Gently lift the controller port board out of its recess within the bottom case. Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Gently lift the controller port board out of its recess within the bottom case.
    • Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Pull the controller port ribbon cable straight away from its socket on the controller port board.
    • Remove the controller port board out of the bottom case.
  8. Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
    • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
  9. If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • Pry and remove the expansion bay cover away from its posts on the bottom case.
  10. Lift the motherboard assembly from its front edge and remove it from the lower case.
    • Lift the motherboard assembly from its front edge and remove it from the lower case.
  11. Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
  12. Lift the expansion bay cage up off the motherboard assembly.
    • Lift the expansion bay cage up off the motherboard assembly.
  13. Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch. Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
    • Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Pull the power board connector straight to lift it out of its socket on the power board.
  14. Underneath where the power supply once was is a transparent piece of plastic.  This is the heat shield, and it can now be removed.
    • Underneath where the power supply once was is a transparent piece of plastic. This is the heat shield, and it can now be removed.
    • It can be a bit stubborn, so it may take a little finessing to get it free.
  15. Now with the heat shield out of the way, you can see there are quite a few screws holding the rest in place. Remove the following screws securing the metal chassis to the logic board:
    • Now with the heat shield out of the way, you can see there are quite a few screws holding the rest in place.
    • Remove the following screws securing the metal chassis to the logic board:
    • Seven 5.8 mm Phillips silver screws.
    • Two 7.4 mm Phillips gold screws.
  16. Unclip flaps, one on one side and two on the other, holding the disc drive together. The first two pictures display where the three flaps are. This is very tricky so take your time. Carefully begin to lift out the disc drive. Beware, there are ribbon cables still attached.
    • Unclip flaps, one on one side and two on the other, holding the disc drive together. The first two pictures display where the three flaps are. This is very tricky so take your time.
    • Carefully begin to lift out the disc drive.
    • Beware, there are ribbon cables still attached.
  17. There are four ribbon cables attached to the disc drive. Be careful not to rip any of them! Remove the three blue ribbon cables and one orange ribbon cable by gently pulling on the blue plastic strips. Carefully remove the orange ribbon cable from the laser by gently pulling on the white plastic strip.
    • There are four ribbon cables attached to the disc drive. Be careful not to rip any of them!
    • Remove the three blue ribbon cables and one orange ribbon cable by gently pulling on the blue plastic strips.
    • Carefully remove the orange ribbon cable from the laser by gently pulling on the white plastic strip.
    • Now the disc drive is free to be removed.
    Hey, ich habe zwar 4 flachbandkabel auf dem laufwerk aber von iwo her habe ich noch eins und ich weiss nicht von wo und er ist sogar ganz ab, was kann ich tun, bitte helfen sie mir.
    MfG David
    David K - Replica
Conclusione
Altre 36 persone hanno completato questa guida.
jwyoung
Membro da: 04/11/2009
2.180 Reputazione
5 Guide realizzate
Cal Poly, Team 19-1, Maness Fall 2009 Membro di Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Membri
33 Guide realizzate
Thank for sharing the material! My PS was broken so I played visa casino for real money for some time. Now I replaced the Disc Drive but I still keep on playing for real money. So I play both. Life is great!
Harriet Allen - Replica
It helped out a lot I was able to fix my
David Sharp - Replica
What replacement drive would you recommend?
Steve Bennett - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 22
Ultimi 7 Giorni: 166
Ultimi 30 Giorni: 708
Tutti i Tempi: 79,779
