Salta al contenuto principale
Plastic Phone Case Crack/Break Repair
Cosa ti serve
  1. Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: passo 1, immagine 1 di 3 Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: passo 1, immagine 2 di 3 Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: passo 1, immagine 3 di 3
    • Clean the cracked area of your phone case with a microfiber towel.
  2. Plastic Phone Case Crack/Break Repair: passo 2, immagine 1 di 2 Plastic Phone Case Crack/Break Repair: passo 2, immagine 2 di 2
    • Sand down the area until smooth.
  3. Plastic Phone Case Crack/Break Repair: passo 3, immagine 1 di 3 Plastic Phone Case Crack/Break Repair: passo 3, immagine 2 di 3 Plastic Phone Case Crack/Break Repair: passo 3, immagine 3 di 3
    • Inject JB Weld epoxy into the provided mixing tray or a container of choice.
    • Use a disposable stick to mix the two elements into a homogeneous solution.
  4. Plastic Phone Case Crack/Break Repair: passo 4, immagine 1 di 2 Plastic Phone Case Crack/Break Repair: passo 4, immagine 2 di 2
    • Use tape to hold the cracked or broken pieces firmly in place, ensuring the edges stay aligned maximizing contact.
  5. Plastic Phone Case Crack/Break Repair: passo 5, immagine 1 di 3 Plastic Phone Case Crack/Break Repair: passo 5, immagine 2 di 3 Plastic Phone Case Crack/Break Repair: passo 5, immagine 3 di 3
    • Grab a small stick or any disposable tool.
    • Generously apply the mixed epoxy along the crack. Make sure to get some epoxy on the internal broken edges.
  6. Plastic Phone Case Crack/Break Repair: passo 6, immagine 1 di 1
    • Once applied, wait 15 minutes for the epoxy to set.
    • Test epoxy strength.
  7. Plastic Phone Case Crack/Break Repair: passo 7, immagine 1 di 1
    • Remove the tape holding the phone case together after the epoxy has cured for long enough for the bonded pieces to stay together.
  8. Plastic Phone Case Crack/Break Repair: passo 8, immagine 1 di 2 Plastic Phone Case Crack/Break Repair: passo 8, immagine 2 di 2
    • Apply epoxy to other side of phone case crack.
  9. Plastic Phone Case Crack/Break Repair: passo 9, immagine 1 di 3 Plastic Phone Case Crack/Break Repair: passo 9, immagine 2 di 3 Plastic Phone Case Crack/Break Repair: passo 9, immagine 3 di 3
    • Wait for 30 minutes for epoxy to cure fully before sanding.
    • Sand the bonded section until smooth.
    • Repeat on the inner side of phone case.
Linea Traguardo
StephenH
Membro da: 04/14/25
169 Reputazione
1 Guida realizzata
UC Davis, Team 1-6, Morris Spring 2025 Membro di UC Davis, Team 1-6, Morris Spring 2025
UCD-MORRIS-S25S1G6
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 61
Tutti i Tempi: 344
