Introduzione
The base unit and headset are synchronized together when you bought them. So if you want to use a replacement headset with the base unit (or if you lose your connection to the base unit) you will need to follow these steps to synchronize the headset to the base:
  1. Ensure the headset is in the base's cradle.
    • Ensure the headset is in the base's cradle.
  2. Press the volume control buttons on the back of the base until the front of the base flashes red.
    • Press the volume control buttons on the back of the base until the front of the base flashes red.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Press the mute switch on top of the headset until the green light on the headset turns on.
    • Press the mute switch on top of the headset until the green light on the headset turns on.
  5. Unplug the power cord for five seconds. After the five seconds are over, reconnect the power cord. Unplug the power cord for five seconds. After the five seconds are over, reconnect the power cord.
    • Unplug the power cord for five seconds. After the five seconds are over, reconnect the power cord.
  6. When the flashing red light becomes solid, synchronization is complete.
    • When the flashing red light becomes solid, synchronization is complete.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Joe
Membro da: 12/04/2012
91 Reputazione
3 Guide realizzate
Cal Poly, Team 17-29, Amido Spring 2012 Membro di Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Membri
7 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,658
