Salta al contenuto principale
Planet Eclipse LV1 Paintball Marker Eye Replacement
Cosa ti serve
  1. Planet Eclipse LV1 Paintball Marker Eye Replacement, Eye: passo 1, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement, Eye: passo 1, immagine 2 di 2
    • Remove the four grip screws with a 5/64" Allen wrench. There are two screws on each side of the marker.
  2. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 2, immagine 1 di 1
    • Remove the rubber grip.
  3. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 3, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 3, immagine 2 di 2
    • On the non-battery side of the marker, unscrew the eye cover with a 5/64" Allen wrench to remove the eye cover.
  4. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 4, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 4, immagine 2 di 2
    • On the battery side of the marker, unscrew the other eye cover with a 5/64" Allen wrench to remove the eye cover.
  5. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 5, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 5, immagine 2 di 2
    • Pull the red and black eye sensor wires to disconnect the plug from the control board.
  6. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 6, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 6, immagine 2 di 2
    • On the battery side of the marker, pull out the red eye sensor wire from the slot.
    • On the non-battery side of the marker, pull out the black eye sensor wire from the slot.
  7. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 7, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 7, immagine 2 di 2
    • On the battery side of the marker, grasp the plug to remove the red and black eye sensor wires.
  8. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 8, immagine 1 di 1
    • With the new eye, pass the plug in between the solenoid and the grip frame.
  9. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 9, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 9, immagine 2 di 2
    • Orient the plug to align with the male receptors of the control board and click into place.
  10. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 10, immagine 1 di 1
    • Grasp the black eye sensor wire and pull it completely through and out of the grip frame on the battery side.
    • Keep the black eye sensor wire out of the way until step 13.
  11. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 11, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 11, immagine 2 di 2
    • Orient the sensor with the flat side facing up.
    • On the battery side of the marker, place the red eye sensor wire into the slot of the marker.
  12. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 12, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 12, immagine 2 di 2
    • Set the eye cover into the slot and secure with the eye cover screw using a 5/64" Allen wrench.
    • Ensure the wires are not pinched between the eye cover and the marker.
  13. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 13, immagine 1 di 1
    • On the battery side of the marker, push the black eye sensor wire through the grip frame and under the solenoid.
  14. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 14, immagine 1 di 1
    • On the non-battery side of the marker, pull through the black eye sensor wire completely.
  15. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 15, immagine 1 di 1
    • On the non-battery side of the marker, place the black eye sensor wire into the slot of the marker.
  16. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 16, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 16, immagine 2 di 2
  17. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 17, immagine 1 di 1
    • Reinstall the rubber grip.
  18. Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 18, immagine 1 di 2 Planet Eclipse LV1 Paintball Marker Eye Replacement: passo 18, immagine 2 di 2
    • Secure the rubber grip with the four grip screws using a 5/64" Allen wrench. There are two screws on each side.
Conclusione
Thank you for viewing this step-by-step guide on replacing an eye for a Planet Eclipse LV1 Paintball Marker. Now get back out there and have fun!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 54
