Introduzione
This guide will show how to replace the eyes and eye wire if either are damaged.
Cosa ti serve
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
Use a prying tool or tweezers to gently remove the connection from the board. It is the connection with 2 black and 2 red wires.
Pull the wire through the opening.
To reassemble your device with a new eye wire, follow this guide in reverse.
