Salta al contenuto principale
Planet Eclipse Etha Regulator Replacement
  1. Planet Eclipse Etha Regulator Replacement, Regulator: passo 1, immagine 1 di 2 Planet Eclipse Etha Regulator Replacement, Regulator: passo 1, immagine 2 di 2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Planet Eclipse Etha Regulator Replacement: passo 2, immagine 1 di 2 Planet Eclipse Etha Regulator Replacement: passo 2, immagine 2 di 2
    • Remove the regulator by unscrewing it in a clockwise direction.
Conclusione
Jared Olson
Membro da: 10/14/14
211 Reputazione
2 Guide realizzate
Cal Poly, Team 10-42, Amido Fall 2014 Membro di Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,255
