Salta al contenuto principale
Planet Eclipse Etha Bolt O-rings Replacement
Cosa ti serve
  1. Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: passo 1, immagine 1 di 3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: passo 1, immagine 2 di 3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: passo 1, immagine 3 di 3
    • Using the 1/4" hex key, turn the bolt counterclockwise and remove.
  2. Planet Eclipse Etha Bolt O-rings Replacement: passo 2, immagine 1 di 2 Planet Eclipse Etha Bolt O-rings Replacement: passo 2, immagine 2 di 2
    • Slide the bolt tip and spring off of the main assembly.
    • Keep a towel handy, you may get some grease on your hands.
  3. Planet Eclipse Etha Bolt O-rings Replacement: passo 3, immagine 1 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 3, immagine 2 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 3, immagine 3 di 3
    • Unscrew the casing from the rest of the bolt.
    • Again, you may get some grease on your hands during this step.
  4. Planet Eclipse Etha Bolt O-rings Replacement: passo 4, immagine 1 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 4, immagine 2 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 4, immagine 3 di 3
    • Grab the flat surface shown.
    • Unscrew this portion counter clockwise to remove it.
    • If you're having trouble unscrewing the part, try using a small wrench.
  5. Planet Eclipse Etha Bolt O-rings Replacement: passo 5, immagine 1 di 2 Planet Eclipse Etha Bolt O-rings Replacement: passo 5, immagine 2 di 2
    • Grab the threaded cover and slide it away from the spring.
    • The bolt should now be in three pieces.
    • The threaded cover is the same part that you unscrewed in the last step.
  6. Planet Eclipse Etha Bolt O-rings Replacement: passo 6, immagine 1 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 6, immagine 2 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 6, immagine 3 di 3
    • Replace and lubricate the 9 marked O-rings.
    • O-ring removal will be explained in the next step.
  7. Planet Eclipse Etha Bolt O-rings Replacement: passo 7, immagine 1 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 7, immagine 2 di 3 Planet Eclipse Etha Bolt O-rings Replacement: passo 7, immagine 3 di 3
    • Grab the O-ring on the sides.
    • Pinch the O-ring upwards to create a gap between the metal and the ring.
    • Use a small object to slip into the loop and pull the O-ring off gently.
    • We recommend using a small Allen Key for this.
Conclusione
nicholasj6
Membro da: 10/14/14
261 Reputazione
2 Guide realizzate
Cal Poly, Team 10-42, Amido Fall 2014 Membro di Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,132
