Salta al contenuto principale
Planet Eclipse Etha Battery and Grip Panels Replacement
Cosa ti serve
  1. Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: passo 1, immagine 1 di 2 Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: passo 1, immagine 2 di 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Battery and Grip Panels Replacement: passo 2, immagine 1 di 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Battery and Grip Panels Replacement: passo 3, immagine 1 di 2 Planet Eclipse Etha Battery and Grip Panels Replacement: passo 3, immagine 2 di 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
Conclusione
Jared Olson
Membro da: 10/14/14
211 Reputazione
2 Guide realizzate
Cal Poly, Team 10-42, Amido Fall 2014 Membro di Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,197
