Salta al contenuto principale
Pioneer Steel Wheels Headphone Headband Replacement
Cosa ti serve
  1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: passo 1, immagine 1 di 2 Pioneer Steel Wheels Headphone Headband Replacement, Headband: passo 1, immagine 2 di 2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Headphone Headband Replacement: passo 2, immagine 1 di 2 Pioneer Steel Wheels Headphone Headband Replacement: passo 2, immagine 2 di 2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Headphone Headband Replacement: passo 3, immagine 1 di 3 Pioneer Steel Wheels Headphone Headband Replacement: passo 3, immagine 2 di 3 Pioneer Steel Wheels Headphone Headband Replacement: passo 3, immagine 3 di 3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
Conclusione
Cal Poly, Team 10-40, Amido Spring 2013 Membro di Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membri
37 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,176
