Salta al contenuto principale
Pioneer Steel Wheels Folding Hinges Replacement
Cosa ti serve
  1. Pioneer Steel Wheels Folding Hinges Replacement, Headband: passo 1, immagine 1 di 2 Pioneer Steel Wheels Folding Hinges Replacement, Headband: passo 1, immagine 2 di 2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Folding Hinges Replacement: passo 2, immagine 1 di 2 Pioneer Steel Wheels Folding Hinges Replacement: passo 2, immagine 2 di 2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Folding Hinges Replacement: passo 3, immagine 1 di 3 Pioneer Steel Wheels Folding Hinges Replacement: passo 3, immagine 2 di 3 Pioneer Steel Wheels Folding Hinges Replacement: passo 3, immagine 3 di 3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: passo 4, immagine 1 di 2 Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: passo 4, immagine 2 di 2
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  5. Pioneer Steel Wheels Folding Hinges Replacement: passo 5, immagine 1 di 2 Pioneer Steel Wheels Folding Hinges Replacement: passo 5, immagine 2 di 2
    • While apart, remove the screw from the headphone.
  6. Pioneer Steel Wheels Folding Hinges Replacement: passo 6, immagine 1 di 2 Pioneer Steel Wheels Folding Hinges Replacement: passo 6, immagine 2 di 2
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  7. Pioneer Steel Wheels Folding Hinges Replacement: passo 7, immagine 1 di 2 Pioneer Steel Wheels Folding Hinges Replacement: passo 7, immagine 2 di 2
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
Conclusione
Cal Poly, Team 10-40, Amido Spring 2013 Membro di Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membri
37 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 465
