Salta al contenuto principale
Pioneer R1 Battery Replacement
Cosa ti serve
  1. Pioneer R1 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Insert your plastic spudger into the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 Battery Replacement: passo 2, immagine 1 di 1
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 Battery Replacement: passo 3, immagine 1 di 1
    • Slide a strong thin object, like a thin spudger, between the battery and the display.
    • Slide the object along the length of the battery to remove it from the display.
    • The adhesive holding the battery in place is strong and the battery is quite soft. Take care not to break open the battery.
    • Disengage the battery cables from the motherboard.
  4. Pioneer R1 Battery Replacement: passo 4, immagine 1 di 1
    • Solder the black cable to the nodule labeled BAT+.
    • Solder the red cable to the nodule labeled BAT-.
    • Do not allow the solder from one nodule to touch the other, this may cause the battery to explode.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 792
