Salta al contenuto principale
Pioneer MXT-X366BT Metal Case Replacement
Cosa ti serve
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: passo 1, immagine 1 di 2 Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: passo 1, immagine 2 di 2
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: passo 2, immagine 1 di 1
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: passo 3, immagine 1 di 1
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: passo 4, immagine 1 di 2 Pioneer MXT-X366BT Metal Case Replacement: passo 4, immagine 2 di 2
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: passo 5, immagine 1 di 1
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: passo 6, immagine 1 di 1
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: passo 7, immagine 1 di 1
    • The metal casing is now fully removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 281
