Salta al contenuto principale
Pioneer MXT-X366BT Face Plate Replacement
  1. Pioneer MXT-X366BT Face Plate Replacement, Face Plate: passo 1, immagine 1 di 1
    • Press the button located on the bottom right hand corner of the radio.
  2. Pioneer MXT-X366BT Face Plate Replacement: passo 2, immagine 1 di 2 Pioneer MXT-X366BT Face Plate Replacement: passo 2, immagine 2 di 2
    • Softly pull the face plate from the backing plate to remove the face plate.
Conclusione
To reassemble your device, attach the left side of the head unit by pressing it into the mounting surface at an angle, then press the right side into place. It will snap in and be snug in place.
Un commento
Hi I'm looking for a pioneer faceplate Deh-s1200ub used do you thing you can find this.
Thank you.
Louis Cordeiro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 14
Tutti i Tempi: 630
