Salta al contenuto principale
Pioneer FH-X730BS USB Port Replacement
Cosa ti serve
  1. Pioneer FH-X730BS USB Port Replacement, Deck Buttons: passo 1, immagine 1 di 3 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: passo 1, immagine 2 di 3 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: passo 1, immagine 3 di 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS USB Port Replacement: passo 2, immagine 1 di 3 Pioneer FH-X730BS USB Port Replacement: passo 2, immagine 2 di 3 Pioneer FH-X730BS USB Port Replacement: passo 2, immagine 3 di 3
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS USB Port Replacement: passo 3, immagine 1 di 3 Pioneer FH-X730BS USB Port Replacement: passo 3, immagine 2 di 3 Pioneer FH-X730BS USB Port Replacement: passo 3, immagine 3 di 3
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS USB Port Replacement, USB Port: passo 4, immagine 1 di 1
    • Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
    • The end of the soldering iron will be hot.
Conclusione
Cody Pesta
Membro da: 09/17/18
688 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,138
