Salta al contenuto principale
Pioneer FH-X730BS Disk Drive Replacement
Cosa ti serve
  1. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: passo 1, immagine 1 di 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: passo 1, immagine 2 di 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: passo 1, immagine 3 di 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Disk Drive Replacement: passo 2, immagine 1 di 1
    • After removing the stereo face from the frame, it should look similar to this.
  3. Pioneer FH-X730BS Disk Drive Replacement: passo 3, immagine 1 di 1
    • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
  4. Pioneer FH-X730BS Disk Drive Replacement: passo 4, immagine 1 di 3 Pioneer FH-X730BS Disk Drive Replacement: passo 4, immagine 2 di 3 Pioneer FH-X730BS Disk Drive Replacement: passo 4, immagine 3 di 3
    • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
  5. Pioneer FH-X730BS Disk Drive Replacement: passo 5, immagine 1 di 3 Pioneer FH-X730BS Disk Drive Replacement: passo 5, immagine 2 di 3 Pioneer FH-X730BS Disk Drive Replacement: passo 5, immagine 3 di 3
    • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
    • Replace the old disk drive with a new one.
Conclusione
Cody Pesta
Membro da: 09/17/18
688 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 307
