Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
A faulty auxiliary inlet can cause the user unable to play media to the radio receiver. This guide will show you how to replace the Auxiliary Inlet for the Pioneer FH-X730BS.
Parti
Nessuna parte specificata.
  1. Apply pressure to the tabs on each side using the plastic opening tool. You will need to pull the face away from the frame while unhooking the tabs. You will need to pull the face away from the frame while unhooking the tabs.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. After removing the stereo face from the frame it should look similar to this. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Remove the volume knob by pulling it towards you and pull the motherboard out of the face. The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons. You can now insert the replacement audio buttons into the face.
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Here you are able to desolder the auxiliary ports  from the circuit board and solder a replacement auxiliary port on.
    • Here you are able to desolder the auxiliary ports from the circuit board and solder a replacement auxiliary port on.
    • The end of the soldering iron will be hot.
Conclusione
Cody Pesta
Membro da: 17/09/2018
667 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 55
