Salta al contenuto principale
Pioneer Elite PRO-RO6U Optical Drive Replacement
Cosa ti serve
  1. Pioneer Elite PRO-RO6U Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 2, immagine 1 di 1
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 3, immagine 1 di 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
    Chiedi a FixBot
    Aggiungi Commento
  4. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 4, immagine 1 di 1
    • Remove the optical drive cooling fan by gripping the ribbon connector at M11 and gently remove by pulling away from the slot.
    Chiedi a FixBot
    Aggiungi Commento
  5. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 5, immagine 1 di 1
    • Flip the latch on the ribbon connector upward to allow for cable removal.
    • Grip the ribbon cable and remove by gently pulling away from the unlatched connector.
    Chiedi a FixBot
    Aggiungi Commento
  6. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 6, immagine 1 di 1
    • Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
    Chiedi a FixBot
    Aggiungi Commento
  7. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 7, immagine 1 di 1
    • Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
    Chiedi a FixBot
    Aggiungi Commento
  8. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 8, immagine 1 di 1
    • Unplug ribbon cables D4 and D5. To unplug D4, flip the gate up and pull the ribbon away.
    Chiedi a FixBot
    Aggiungi Commento
  9. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 9, immagine 1 di 1
    • Remove four 1/4th inch Phillips screws on the back of the casing.
    • Unscrew and remove the nut from the threaded connector.
    Chiedi a FixBot
    Aggiungi Commento
  10. Pioneer Elite PRO-RO6U Optical Drive Replacement: passo 10, immagine 1 di 1
    • The optical drive is still connected by a cable on its bottom side, lift the drive upwards only slightly when first removing from the casing.
    • Pull the optical drive toward the interior of the device and then lift upwards, then pull to remove the cord on the bottom left corner before removing the drive completely.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cody Carter
Membro da: 01/30/18
1.049 Reputazione
6 guide realizzate
Baylor, Team S1-G5, Johnson Spring 2018 Membro di Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 34
Tutti i Tempi: 555
