Salta al contenuto principale
Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement
Cosa ti serve
  1. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement, Optical Drive Cooling Fan: passo 1, immagine 1 di 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
    Chiedi a FixBot
    Aggiungi Commento
  4. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: passo 4, immagine 1 di 1
    • To replace the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
    Chiedi a FixBot
    Aggiungi Commento
  5. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Flip the latch on the ribbon connector upward to allow for cable removal.
    • Grip the ribbon cable and remove by gently pulling away from the unlatched connector.
    Chiedi a FixBot
    Aggiungi Commento
  6. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
    Chiedi a FixBot
    Aggiungi Commento
  7. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: passo 7, immagine 1 di 1
    • Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cody Carter
Membro da: 01/30/18
1.049 Reputazione
6 guide realizzate
Baylor, Team S1-G5, Johnson Spring 2018 Membro di Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 48
Tutti i Tempi: 532
