Salta al contenuto principale
Pioneer Elite PRO-RO6U Motherboard Replacement
Cosa ti serve
  1. Pioneer Elite PRO-RO6U Motherboard Replacement, Power Supply Cooling Fan: passo 1, immagine 1 di 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 3, immagine 1 di 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
    Chiedi a FixBot
    Aggiungi Commento
  4. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 4, immagine 1 di 1
    • To replace the back cooling fan, grip the ribbon connector at slot M10 and remove by gently pulling upward.
    Chiedi a FixBot
    Aggiungi Commento
  5. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the two 6.5 mm Phillips mounting screws at the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
  6. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 6, immagine 1 di 1
    • Grip the frame of the cooling fan and slide away from the back wall until the tabs are no longer in the holes of the casing.
    • Lift the cooling fan out of the device.
    Chiedi a FixBot
    Aggiungi Commento
  7. Pioneer Elite PRO-RO6U Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • To remove the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
    Chiedi a FixBot
    Aggiungi Commento
  8. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 8, immagine 1 di 1
    • Flip the latch on the ribbon connector upward to allow for cable removal.
    • Grip the ribbon cable and remove by gently pulling away from the unlatched connector.
    Chiedi a FixBot
    Aggiungi Commento
  9. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
    Chiedi a FixBot
    Aggiungi Commento
  10. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 10, immagine 1 di 1
    • Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
    Chiedi a FixBot
    Aggiungi Commento
  11. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 11, immagine 1 di 1
    • Unplug ribbon cables D4 and D5. To unplug D4, flip the gate up and pull the ribbon away.
    Chiedi a FixBot
    Aggiungi Commento
  12. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove four 1/4th inch Phillips screws on the back of the casing.
    • Unscrew and remove the nut from the threaded connector.
    Chiedi a FixBot
    Aggiungi Commento
  13. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 13, immagine 1 di 2 Pioneer Elite PRO-RO6U Motherboard Replacement: passo 13, immagine 2 di 2
    • The optical drive is still connected by a cable on its bottom side, lift the drive upwards only slightly when first removing from the casing.
    • Pull the optical drive toward the interior of the device and then lift upwards, then pull to remove the cord on the bottom left corner before removing the drive completely.
    Chiedi a FixBot
    Aggiungi Commento
  14. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 14, immagine 1 di 2 Pioneer Elite PRO-RO6U Motherboard Replacement: passo 14, immagine 2 di 2
    • Unplug connectors at M1, M4, M7, M8, M9 by gently pulling upward.
    • Remove all 3/8 inch Phillips screws connecting motherboard to casing.
    Chiedi a FixBot
    Aggiungi Commento
  15. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 15, immagine 1 di 1
    • Remove the five 1/4 inch Phillips screws and two 1/8 inch Phillips screws on the back of the casing.
    • Unscrew and remove nut from threaded connector.
    Chiedi a FixBot
    Aggiungi Commento
  16. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove four 1/2 inch screws using a nutdriver.
    Chiedi a FixBot
    Aggiungi Commento
  17. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 17, immagine 1 di 1
    • Pinch the securing tabs and lift the motherboard toward the interior of the device to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  18. Pioneer Elite PRO-RO6U Motherboard Replacement: passo 18, immagine 1 di 1
    • Pull it toward the interior of the device and lift it away.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cody Carter
Membro da: 01/30/18
1.049 Reputazione
6 guide realizzate
Baylor, Team S1-G5, Johnson Spring 2018 Membro di Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 35
Tutti i Tempi: 1,155
