Introduzione
Replacing the motherboard of the Pioneer Elite Pro-R06U may be necessary if the receiver is dropped or takes water damage. This part is the trickiest to replace as it is located beneath all other components of the receiver.
Cosa ti serve
Remove the two 6.4 mm Phillips screws on each side of the device's casing.
To remove the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
