Salta al contenuto principale
Pioneer A1 XW-SMA1-K Back Panel Replacement
Cosa ti serve
  1. Pioneer A1 XW-SMA1-K Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Back Panel Replacement: passo 2, immagine 1 di 2 Pioneer A1 XW-SMA1-K Back Panel Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Back Panel Replacement: passo 3, immagine 1 di 3 Pioneer A1 XW-SMA1-K Back Panel Replacement: passo 3, immagine 2 di 3 Pioneer A1 XW-SMA1-K Back Panel Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Back Panel Replacement: passo 4, immagine 1 di 2 Pioneer A1 XW-SMA1-K Back Panel Replacement: passo 4, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 646
