Salta al contenuto principale
Pine64 PinePhone Charging Port Replacement
Cosa ti serve
  1. Pine64 PinePhone Charging Port Replacement, Back Cover: passo 1, immagine 1 di 2 Pine64 PinePhone Charging Port Replacement, Back Cover: passo 1, immagine 2 di 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Charging Port Replacement: passo 2, immagine 1 di 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Charging Port Replacement, Charging Port: passo 3, immagine 1 di 3 Pine64 PinePhone Charging Port Replacement, Charging Port: passo 3, immagine 2 di 3 Pine64 PinePhone Charging Port Replacement, Charging Port: passo 3, immagine 3 di 3
    • Using a Phillips #000 screwdriver, remove each of the screws around the perimeter of the PinePhone.
    • Remove the battery.
  4. Pine64 PinePhone Charging Port Replacement: passo 4, immagine 1 di 1
    • Remove the midframe from the phone.
  5. Pine64 PinePhone Charging Port Replacement: passo 5, immagine 1 di 1
    • Carefully lift up the vibrator, connected to the board by two wires.
  6. Pine64 PinePhone Charging Port Replacement: passo 6, immagine 1 di 1
    • Applying even pressure, lift up the board.
    • An adhesive is all that is keeping it to the frame of the phone, so there should be minimum resistance.
    • With a new adhesive strip, connect the replacement board to the frame. Make sure to secure the vibrator in the same place as the original.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,051
