Salta al contenuto principale
Picture Frame Matting Replacement
Cosa ti serve
  1. Picture Frame Matting Replacement, Picture Frame Matting: passo 1, immagine 1 di 1
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: passo 2, immagine 1 di 1
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: passo 3, immagine 1 di 2 Picture Frame Matting Replacement: passo 3, immagine 2 di 2
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: passo 4, immagine 1 di 1
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: passo 5, immagine 1 di 1
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: passo 6, immagine 1 di 2 Picture Frame Matting Replacement: passo 6, immagine 2 di 2
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: passo 7, immagine 1 di 1
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: passo 8, immagine 1 di 2 Picture Frame Matting Replacement: passo 8, immagine 2 di 2
    • Rotate the backing clips under the frame to secure it.
Linea Traguardo
Leah
Membro da: 01/20/23
160 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 185
