Salta al contenuto principale
Photive Rain Speaker Replacement
Cosa ti serve
  1. Photive Rain Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Carefully remove the front panel from the device.
  4. Photive Rain Speaker Replacement: passo 4, immagine 1 di 1
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  5. Photive Rain Speaker Replacement: passo 5, immagine 1 di 2 Photive Rain Speaker Replacement: passo 5, immagine 2 di 2
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team 1-4, Harley Spring 2016 Membro di IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 330
