Salta al contenuto principale
Photive Hydra Battery Replacement
Cosa ti serve
  1. Photive Hydra Battery Replacement, Face Plate and Back Plate: passo 1, immagine 1 di 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Battery Replacement: passo 2, immagine 1 di 2 Photive Hydra Battery Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Battery Replacement: passo 3, immagine 1 di 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Battery Replacement: passo 4, immagine 1 di 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Battery Replacement: passo 5, immagine 1 di 2 Photive Hydra Battery Replacement: passo 5, immagine 2 di 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Battery Replacement, Battery (Prerequisite): passo 6, immagine 1 di 2 Photive Hydra Battery Replacement, Battery (Prerequisite): passo 6, immagine 2 di 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Battery Replacement: passo 7, immagine 1 di 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
Conclusione
USF Tampa, Team 11-3, Cheng Spring 2016 Membro di USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Membri
6 Guide realizzate
Un commento
Great instructions, I replaced the battery and it works fine.
THANKS!
Terry - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 489
