Introduzione
The IC (chip) inside the lamp seems to die slowly resulting in flickering/flashing lamp operation when using the radio. Also the buttons may become unresponsive.
The problem occurs specifically when the device is cold and/or humid. Heating up the IC makes it work again.
Strumenti
Nessun attrezzo specificato.
Parti
Disassemble according to this guide:
On the main PCB with the power-jack, replace the MTX2410 switchmode regulator IC (SO-8 Package).
There is a pin-compatible device from Quorvo (ACT4060ASH-T) which has a different internal voltage reference but otherwise works fine. Only a resistor must be changed for this to work.
Feedback Voltage for MXT2410 is 1.222V, for ACT4060 is 1.293V, so voltage divider on Pin5 must be changed accordingly.
One can best adjust R4+R3 (series). Remove R4, measure R3 and R4, and increase. It should measure about 10.67kOhm (R3 plus R4), and it can be slightly increased to 11.51kOhm. So basically add 1kOhm to R3+R4.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Altre 2 persone hanno completato questa guida.
7 Commenti
Thank like '''เกมสล็อต''' you :DDD
Thank you '''สล็อตออนไลน์''' my friend :DDD
Hi Thomas,
I have the same problem, but i do not understand what you are doing with the R3 and R4. If i remove R4, with what should i replace it?
Or how should i measure it?
Thanks in advance,
Arnoud
d mark mark lay '''สล็อตออนไลน์'''
เล่นแล้วสบายใจได้เงินจริง สล็อตออนไลน์
