Salta al contenuto principale
Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
Cosa ti serve
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: passo 1, immagine 1 di 3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: passo 1, immagine 2 di 3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: passo 1, immagine 3 di 3
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 2, immagine 1 di 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 3, immagine 1 di 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 3, immagine 2 di 2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: passo 4, immagine 1 di 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: passo 4, immagine 2 di 2
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 5, immagine 1 di 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 5, immagine 2 di 2
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 6, immagine 1 di 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: passo 6, immagine 2 di 2
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
Conclusione
Liam Casto
Membro da: 04/01/24
354 Reputazione
3 Guide realizzate
IUPUI, Team 1-4, Harley Spring 2024 Membro di IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 204
