Salta al contenuto principale
Philips Sonicare FlexCare Spring Replacement
Cosa ti serve
  1. Philips Sonicare FlexCare Spring Replacement, Spring: passo 1, immagine 1 di 1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Spring Replacement: passo 2, immagine 1 di 2 Philips Sonicare FlexCare Spring Replacement: passo 2, immagine 2 di 2
    • Push the flat edge of a nylon or metal spudger between the seal and the toothbrush body and pry it up. Do this on each side until the seal is partially sticking out on all sides.
  3. Philips Sonicare FlexCare Spring Replacement: passo 3, immagine 1 di 1
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the interior electronics are exposed.
  4. Philips Sonicare FlexCare Spring Replacement: passo 4, immagine 1 di 1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Spring Replacement: passo 5, immagine 1 di 1
    • Pull off the black rubber ring with a metal or nylon spudger until it clears the metal piece that holds it in place. Pull the ring out.
  6. Philips Sonicare FlexCare Spring Replacement: passo 6, immagine 1 di 1
    • Remove the spring from the rubber ring and replace it with the new spring.
Conclusione
Altre 4 persone hanno completato questa guida.
Joanna Moraza
Membro da: 04/14/15
1.783 Reputazione
2 Guide realizzate
Cal Poly, Team 4-6, Maness Spring 2015 Membro di Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 Membri
23 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 51
Tutti i Tempi: 5,142
