Unplug the device and remove the purple guard.
  • Unplug the device and remove the purple guard.
  • Remove the head by pressing the right side of the head (with the device facing away from you).
  • You will hear a 'click' and the head will become dislodged from the body of the device.
Aggiungi Commento
While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the  tensor clip.
  • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
  • Be careful not to lose the clip. It will likely fly off when it releases.
Aggiungi Commento
  • The left side will swing down.
  • Remove the Tweezers.
Aggiungi Commento
  • Remove the plastic component that swings down.
  • Use fingernails to lift clips from stubs.
Aggiungi Commento
  • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
Aggiungi Commento
  • Use a spudger to pry the gear housing unit from the base.
Aggiungi Commento
  • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
Aggiungi Commento
  • Replace Tweezer Head.
  • Ensure that the gear is inserted into the gear box end of the head.
  • When closing the head, make sure that the Tweezer is seated correctly. To check this, the tweezers should spin fairly easily with the finger.
Aggiungi Commento
Conclusione
Nathan Christian
Membro da: 11/11/2017
440 Reputazione
4 Guide realizzate
IUPUI, Team S5-G5, Wilson Fall 2017 Membro di IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 121
