Salta al contenuto principale
Philips Satinelle Plastic Cover Replacement
Cosa ti serve
  1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: passo 1, immagine 1 di 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: passo 1, immagine 2 di 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: passo 1, immagine 3 di 3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Plastic Cover Replacement: passo 2, immagine 1 di 2 Philips Satinelle Plastic Cover Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Plastic Cover Replacement: passo 3, immagine 1 di 1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
Conclusione
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
Marist, Team S1-G1, Chaterdon Fall 2018 Membro di Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 630
