Salta al contenuto principale
Philips Satinelle On/Off Switch Replacement
Cosa ti serve
  1. Philips Satinelle On/Off Switch Replacement, Plastic Cover: passo 1, immagine 1 di 3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: passo 1, immagine 2 di 3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: passo 1, immagine 3 di 3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle On/Off Switch Replacement: passo 2, immagine 1 di 2 Philips Satinelle On/Off Switch Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle On/Off Switch Replacement: passo 3, immagine 1 di 1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
  4. Philips Satinelle On/Off Switch Replacement, On/Off Switch: passo 4, immagine 1 di 1
    • Remove the green board and the black socket.
  5. Philips Satinelle On/Off Switch Replacement: passo 5, immagine 1 di 1
    • Slide the switch down toward the socket.
  6. Philips Satinelle On/Off Switch Replacement: passo 6, immagine 1 di 3 Philips Satinelle On/Off Switch Replacement: passo 6, immagine 2 di 3 Philips Satinelle On/Off Switch Replacement: passo 6, immagine 3 di 3
    • Put the components back into the frame
    • If the switch won't line up with the plastic square, make sure the large switch on the front of the operator is in the "off" position.
Conclusione
Marist, Team S1-G1, Chaterdon Fall 2018 Membro di Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Membri
8 Guide realizzate
Un commento
Very precise instructions, thanks!
carlos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,682
