Salta al contenuto principale
Philips Satinelle Motor Replacement
Cosa ti serve
  1. Philips Satinelle Motor Replacement, Plastic Cover: passo 1, immagine 1 di 3 Philips Satinelle Motor Replacement, Plastic Cover: passo 1, immagine 2 di 3 Philips Satinelle Motor Replacement, Plastic Cover: passo 1, immagine 3 di 3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Motor Replacement: passo 2, immagine 1 di 2 Philips Satinelle Motor Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Motor Replacement: passo 3, immagine 1 di 1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
  4. Philips Satinelle Motor Replacement, Motor: passo 4, immagine 1 di 2 Philips Satinelle Motor Replacement, Motor: passo 4, immagine 2 di 2
    • Remove the components.
  5. Philips Satinelle Motor Replacement: passo 5, immagine 1 di 3 Philips Satinelle Motor Replacement: passo 5, immagine 2 di 3 Philips Satinelle Motor Replacement: passo 5, immagine 3 di 3
    • Hold the motor with the gears face away from you.
    • Gently push the motor out with your thumbs.
Conclusione
Marist, Team S1-G1, Chaterdon Fall 2018 Membro di Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Membri
8 Guide realizzate
2 Commenti
i dont know what i am doing wrong but it is not openning
Aj Queen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,228
