Salta al contenuto principale
Philips Satinelle Metal Rolling Tracks Replacement
Cosa ti serve
  1. Philips Satinelle Metal Rolling Tracks Replacement, Philips Satinelle Disassembly: passo 1, immagine 1 di 2 Philips Satinelle Metal Rolling Tracks Replacement, Philips Satinelle Disassembly: passo 1, immagine 2 di 2
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Metal Rolling Tracks Replacement: passo 2, immagine 1 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 2, immagine 2 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 2, immagine 3 di 3
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Metal Rolling Tracks Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Metal Rolling Tracks Replacement: passo 4, immagine 1 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 4, immagine 2 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 4, immagine 3 di 3
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Metal Rolling Tracks Replacement: passo 5, immagine 1 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 5, immagine 2 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 5, immagine 3 di 3
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Metal Rolling Tracks Replacement: passo 6, immagine 1 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 6, immagine 2 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 6, immagine 3 di 3
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Metal Rolling Tracks Replacement: passo 7, immagine 1 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 7, immagine 2 di 3 Philips Satinelle Metal Rolling Tracks Replacement: passo 7, immagine 3 di 3
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Metal Rolling Tracks Replacement, Metal Rolling Tracks Replacement: passo 8, immagine 1 di 1
    • Replace Metal Roller Tracks on both sides of the Tweezer Head.
Conclusione
IUPUI, Team S5-G5, Wilson Fall 2017 Membro di IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 646
