Salta al contenuto principale
Philips Respironics V60 Touchscreen Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
  1. Philips Respironics V60 Touchscreen Replacement, Touchscreen: passo 1, immagine 1 di 1
    • From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
    • Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
    • NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
    • If the calibration is not successful, have the ventilator serviced.
  2. Philips Respironics V60 Touchscreen Replacement: passo 2, immagine 1 di 1
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
  3. Philips Respironics V60 Touchscreen Replacement: passo 3, immagine 1 di 1
    • Remove the screws from the end cap and remove the end cap.
    • Remove the screws from the rear bezel.
    • Separate the front and rear bezel.
  4. Philips Respironics V60 Touchscreen Replacement: passo 4, immagine 1 di 1
    • Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
    • Remove the switch PCBA.
    • Remove the screw that attaches the cable clamp to the LCD tray.
    • Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
    • Remove the touch screen from the front bezel.
Conclusione
Weihan Du
Membro da: 04/11/20
241 Reputazione
2 Guide realizzate
Cal Poly, Team S7-G10, Paton Spring 2020 Membro di Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,020
