Salta al contenuto principale
Philips Respironics V60 Fan Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
  1. Philips Respironics V60 Fan Replacement, shut down the ventilator: passo 1, immagine 1 di 2 Philips Respironics V60 Fan Replacement, shut down the ventilator: passo 1, immagine 2 di 2
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    • Disconnect the ventilator from the AC power.
    • Unplug the ventilator
  2. Philips Respironics V60 Fan Replacement: passo 4, immagine 1 di 1
    • Disconnect the internal battery from the power harness connector.
  3. Philips Respironics V60 Fan Replacement, Top Cover: passo 5, immagine 1 di 1
    • Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
    • Then remove the right side panel.
  4. Philips Respironics V60 Fan Replacement: passo 6, immagine 1 di 1
    • Remove the 4 screws using a screwdriver.
    • Remove the top cover.
  5. Philips Respironics V60 Fan Replacement, Fan: passo 7, immagine 1 di 1
    • Remove the fan mount push pins that attach the fan to the back panel.
    • Pliers may be required.
  6. Philips Respironics V60 Fan Replacement: passo 8, immagine 1 di 1
    • Disconnect fan cable from motor controller.
  7. Philips Respironics V60 Fan Replacement: passo 9, immagine 1 di 1
    • Remove fan,
    • from back panel.
  8. Philips Respironics V60 Fan Replacement: passo 10, immagine 1 di 1
    • Remove fan filter assembly (the fan filter and housing), from outside the back panel.
    • When installing, orient the fan with the fan cable at the top inside of the fan, and orient the fan filter and housing as shown.
Conclusione
Rie Kuraoka
Membro da: 01/23/20
886 Reputazione
7 Guide realizzate
Cal Poly, Team S7-G10, Paton Spring 2020 Membro di Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 646
