Salta al contenuto principale
Philips Respironics V200 Esprit Oxygen Valve Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
  1. Philips Respironics V200 Esprit Oxygen Valve Replacement, Oxygen Valve: passo 1, immagine 1 di 1
    • Before replacing the oxygen valve assembly:
    • You must install the oxygen regulator assembly before reinstalling the oxygen valve assembly
    • When reinstalling the oxygen valve, make sure the oxygen regulator and oxygen flow sensor are fully installed to the oxygen valve assembly
    • Always inspect the O-rings between interconnecting parts, and replace them if they are visibly damaged or rough to the touch.
    • Always use new O-rings supplied with replacement parts
    • Lightly lubricate O-rings with Krytox GPL226 lubricant when installing, and relubricate at every reinstallation
  2. Philips Respironics V200 Esprit Oxygen Valve Replacement: passo 2, immagine 1 di 1
    • Remove the oxygen flow sensor
    • (Instructions found in Chapter 10.26 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Careful! Do not cut the tie wrap or disconnect the O2 F/S cable from the flow sensor.
  3. Philips Respironics V200 Esprit Oxygen Valve Replacement: passo 3, immagine 1 di 1
    • Remove the air flow sensor
    • (Instructions found in Chapter 10.27 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Careful! Do not cut the tie wrap or disconnect the AIR F/S cable from the flow sensor.
  4. Philips Respironics V200 Esprit Oxygen Valve Replacement: passo 4, immagine 1 di 1
    • Remove the air valve assembly
    • (Instructions found in Chapter 10.30 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Disconnect the two MTR O2 cables on the oxygen valve from the mating MTR O2 cable
    • Disconnect the CROSS SOL cable from the crossover solenoid valve
    • Using a 8-mm socket with extension, remove the three bolts that hold the oxygen valve bracket
    • Slowly pull the oxygen valve assembly away from the oxygen regulator
Conclusione
Grace Gius
Membro da: 05/04/20
505 Reputazione
3 Guide realizzate
Cal Poly, Team S1-G4, Zimmerman Spring 2020 Membro di Cal Poly, Team S1-G4, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G4
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 277
