Introduzione
There is this great teardown guide for Philips Steam Iron:
Philips Pressurised Steam Generator GC8220 Teardown
I want to clarify about its temperature sensor; that if faulty, it will make problems for the steam function.
If no Philips spare part is available to you, it can be replaced with a generic from electronics component shops.
The Temperature Sensor is attached to the bottom of the Boiler unit.
It is an NTC Thermistor.
Altre 4 persone hanno completato questa guida.
5 Commenti
With GC9640 the termistor is 226 kOhm @ 26°C.
Beim GC9640 hat der NTC 226 kOhm bei 26°C
Hi all , Does anyone know how much should be the resistance on ohm of the boiler of Philips iron steamer GC9241.Thanks
