Salta al contenuto principale
Philips Norelco OneBlade Exterior Casing Replacement
Cosa ti serve
  1. Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: passo 1, immagine 1 di 3 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: passo 1, immagine 2 di 3 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: passo 1, immagine 3 di 3
    • Ensure razor is off, and razor blade has been removed.
  2. Philips Norelco OneBlade Exterior Casing Replacement: passo 2, immagine 1 di 2 Philips Norelco OneBlade Exterior Casing Replacement: passo 2, immagine 2 di 2
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull top razor apart.
    • Caution, device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Exterior Casing Replacement: passo 3, immagine 1 di 1
    • Power button should face forward in same direction as circuit board. The crease on each casing component should line up.
Conclusione
Please dispose of exterior casing properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
IUPUI, Team S3-G3, Harley Fall 2017 Membro di IUPUI, Team S3-G3, Harley Fall 2017
IUPUI-HARLEY-F17S3G3
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 93
Tutti i Tempi: 3,636
