Salta al contenuto principale
Philips Norelco MultiGroom 3100 Casing Replacement
Cosa ti serve
  1. Philips Norelco MultiGroom 3100 Casing Replacement, Power Button: passo 1, immagine 1 di 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Casing Replacement: passo 2, immagine 1 di 2 Philips Norelco MultiGroom 3100 Casing Replacement: passo 2, immagine 2 di 2
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Casing Replacement: passo 3, immagine 1 di 2 Philips Norelco MultiGroom 3100 Casing Replacement: passo 3, immagine 2 di 2
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Casing Replacement: passo 4, immagine 1 di 1
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Casing Replacement, Casing: passo 5, immagine 1 di 2 Philips Norelco MultiGroom 3100 Casing Replacement, Casing: passo 5, immagine 2 di 2
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Casing Replacement: passo 6, immagine 1 di 2 Philips Norelco MultiGroom 3100 Casing Replacement: passo 6, immagine 2 di 2
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
Conclusione
Altre 9 persone hanno completato questa guida.
USF Tampa, Team 1-1, Leahy Fall 2015 Membro di USF Tampa, Team 1-1, Leahy Fall 2015
USFT-LEAHY-F15S1G1
2 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,974
